Hydraulic fluid blow out through filter
   / Hydraulic fluid blow out through filter #1
LDD
So I changed the hydraulic fluid in my Kubota b2150 hst. But, I did not change the filter because the manual says every 300 hrs. Soooo, I drained the fluid and re-filled it, cleaned the strainer etc...I started up the tractor and warmed it up. When I started to plow my driveway I thought I smelled a bit of fluid but I didn't think anything of it. Then, it dumped all the new trans fluid out the seal of the filter. It seemed like it blew it out. When I took the filter off it looked like the inside of the filter was crushed. What did I do? Was there some sort of pressure build up? should I have loosened the filter when I drained the fluid? Thanks in advance for any responses.
   / Hydraulic fluid blow out through filter #2
Check for a clogged tank vent or the fill cap. As fluid heats, it is going to expands.
Pressure will depend on heat and space.
Those filters and housing are low pressure filter assembly.
   / Hydraulic fluid blow out through filter #3
Hmmmmmm.....other than air being ahead of the fluid forced toward the filter,sounds like maybe the filter was just ready to go. don-ohio
Yeah, I think you might be right Don. I've since looked at the manual again and for some reason I had it stuck in my head that the filter only needed to be changed every 100 but it is every 50 hrs and this one was overdue.
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52705)
2016 CATERPILLAR...
