hydraulic flow rate
   / hydraulic flow rate #1
Anonymous Poster
Epic Contributor
I have a question regarding the hydraulic system on my TC25D. Does anyone know of a way to increase the flow rate on the hydraulic system that runs the FEL and backhoe attachments? My guess is that I'm stuck with what I've got, but I just wanted to check. I wondered if any "tinkerers" out there have fitted a different pump and gotten away from the OEM unit. Maybe a modification to the OEM pump will work. Any suggestions?
   / hydraulic flow rate #2
You could add a pto powered pump, would probably be cheaper in the long run, rather than risk messing up the factory pump.
   / hydraulic flow rate #3
I havn't looked at the pump schematics.. but doubt that it has any restrictor plates or bushings. Keep in mind that while you may be able to change out the pump with a larger model, that the drive where this pump gets its power from the engine is only rated at a specific load... a huge monster pump may load the system excessively, breaking the drive shaft / coupler.. then you're in trouble..
Soundguy
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
2015 JLG Triple-L Flatbed T/A Trailer (A50323)
2015 JLG Triple-L...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 FREIGHTLINER CASCADIA DAY CAB (A52141)
2016 FREIGHTLINER...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
