Hydraulic Float Question
   / Hydraulic Float Question #1
blueriver
Elite Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I took delivery of my new V hay rake today. One hyd cylinder with one hose, the owners manual states ...
"The V rake is designed to be operated with the hydraulic cylinder in the float position allowing the rake beam to float up and down without the cylinder restricting its motion"
Then it goes on to state "If your tractor does not have a float position you will need the second hose option"
So, does the second hose actually allow the float of the cylinder without using the tractor float?
   / Hydraulic Float Question #2
Thanks JJ ... neither one of my tractors (I don't think) have the float on the rear remotes ... at least I am aware of.
So again the question is does the second hose actually serve the same purpose?
   / Hydraulic Float Question #4
I do not think here is not enough info about definition of "2nd hose", to answer that...but J_J's valve will work if you plug one port on the float valve...
Drawing
Drawing
Yes the 2nd hose definition is why the question ... I like the valve ... has me questioning things!!
   / Hydraulic Float Question #6
If he only has a single hose, it would make it an SA cylinder? so the diagram and valve would not work... it's for a DA cylinder... correct?
   / Hydraulic Float Question #8
Drawing
Plug = close off... Got it, sorry, Plug for me went the other way "plug in" So, we need to know what "2nd hose" means...
   / Hydraulic Float Question #9
Drawing
With the the 4 way valve in neutral,
Why would you plug any port on the float valve. The float valve simply allows the fluid in the cyl to draw and push fluid into the tank. It has to have the return line connected, and the two cyl hoses. Am I missing something here. With the knob pushed in, the cyl works normally. Pull the knob out, and the fluid is free to move to and from the tank.
   / Hydraulic Float Question #10
...and the two cyl hoses. Am I missing something here...
"...One hyd cylinder with one hose..."
One not two...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2017 Ram ProMaster City Cargo Van (A51692)
2017 Ram ProMaster...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
