Hydraulic Fittings Leaking
   / Hydraulic Fittings Leaking #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
Hi Folks.
Have been having a problem with leaks on the hoses that go from the loader control to the loader. A professional replaced one of the hoses but still had leakage so decided to replace the other three hoses. Had them made at an hydraulic shop. The problem area is with the fittings that connect to the loader metal hoses. Part of the problem is I have not had experience with this hydraulics before and am a mediocre amateur mechanic at best. The fittings have tapered ends and I and the shop assumed they were JIC which they may be.
First time I installed them I tightened them what seemed like fairly tight. Had some drips when ran the loader. Second time I did not tighten them as much since internet research indicated leaks usually due to over tightening with JIC fittings. Leaked worse. Third time I tried putting a Loctite 561 Thread Sealant (stick) on the threads that I got from the hydraulic store for the coupler ends which were NPT type thread. I know you should not need it on JIC but what the heck. Still leaked worse.
So any helpful ideas?
Anybody know if Kioti actually uses the common American JIC 37 degree flare or the Japanese JIS 30* flare? I read somewhere that the JIS 30 is also common in Korea.
Please keep in mind that it may sound like I know what I'm talking about but it's from the internet, not personal experience.
Thanks for your help!
   / Hydraulic Fittings Leaking #2
JIS and JIC have different threads as well as different tapers so they won't screw together short of forcing them. Maybe a picture of the fittings in question would help identify the problem.
   / Hydraulic Fittings Leaking #3
And there is this.... JIC 37° and SAE 45° Flare has same thread size and thread count... See Page 4 & 5
  • thread_guide.pdf
2020 KUBOTA RTV...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
