Hydraulic fittings 2310.
   / Hydraulic fittings 2310. #1
2310 guy
Bronze Member
BI, BC, Canada
MF 2310
I was wondering if anyone knows the what fitting the FEL use's? Apparently my dealer doesn't Know??? They said the loader has a plate stating were its made. If its made in the USA it will be a standard fitting and if its made else were it could be metric:confused:
So what I'm saying is they were no help at all. I think they were busy so they put me throught to some sales guy insted of service.
I'm sure there is somebody here who knows if its JIC, ORB, NPT, metric, etc. This forums is full of knowledgeable people and I haven't be disappointed yet.
Thanks in advance, KC
   / Hydraulic fittings 2310. #2
2310 Guy-
Are you looking for the quick disconnect fittings?
I just replaced the ones on my BH and they were Safeway S45-2 couplings 1/4 NPT. I replaced them with Pioneer part # VP40000-2P 1/4" 3000PSI 1/4NPT couplings. I just checked the FEL and it uses the same Safeway part # so I would guess all the fittings are 1/4 NPT. Hope it helps.....
   / Hydraulic fittings 2310. #3
Also look on the Nimco Controls website. I think if you do some snooping around you will find more info. The FEL control on my 2004 GC2310 is a Nimco 10151.
   / Hydraulic fittings 2310. #4
Hey guy
Sorry I took so long to get back to you. I have been off line with computer problems.
I plumbed my new valve in the power beyond lood going to Hoe.
The valve used ORB the lines used JIC
The QDs used Pipe so I had to convert ORB to Pipe one one side and Pipe to JIC on the other.
I disconnected the Hoe's power beyond at the Loader valve (this is the large one on the right side of the valve.
I ran a new hose from the here to the inlet of the new valve.
I added a Tee (all JIC) to the low pressure outlet of the loader - (This is the one on the right hand side front of the loader valve).
I connected The outlet of the new valve to the tee.
My new valve had a power beyond port. I then tied to existing supply to the hoe which I had disconnected from the PB of the loader to the PB of the new valve.
Dan\
So what size are the three JIC fitting that original went to the loader valve?
Thanks KC
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
23222 (A50323)
23222 (A50323)
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
