Hydraulic Filter
   / Hydraulic Filter #1
Singlemalt
Bronze Member
Ontario, Canada
Kioti DS4110HS
Greetings all.
Just moved over to a Kioti DS4110HS.
I've sourced out NAPA or WIX for the air and oil filters but can't find a Hydraulic filter substitute. WIX recognize it as a valid part number but offer no subs at this time.
Most of the Kioti tractors seem to use the same filters.
Cub Cadet list a DD T4620-38032 filter but the DD throws me. Would this be the same filter with the DD a Cub Cadet coding?
Pricing seems to be in the $30-$35 range but convenience of picking it up is a problem.
Can anyone tell me what substitute they are using for the T4620-38032 filter, if any.
Any help would be appreciated.
   / Hydraulic Filter #2
You have just hit on the on going question. So far we have not been able to find a hydraulic filter other the Kioti. I just today bought one for my CK30. $49.89 I guess they want to stay under 50. Good luck on the search and if successful PLEASE tell us
   / Hydraulic Filter #3
Currently it seems the U.S filter manufactures do not see enough population, usage of this filter to justify cost of making it. Not all Kioti models use the same hydraulic filters so this makes the population even less for each filter. Have you checked with Kioti dealer on price of the air and engine oil filters? There has been several posts in here about the cross over to aftermarket and most of the time guys have found price at dealer is same or less than auto parts stores.
   / Hydraulic Filter #4
The Cub Cadet filter starting with DD is just a Kioti filter. I have a Cub Cadet 8404, which is a Kioti DK40 with a yellow and white paint job instead of orange. Cub Cadet sold the DK35 (8354), DK40 (8404), and DK45 (8454) for a couple years around 2004. I order all my parts from CubCadet.com, and every part number starts with DD for Daedong. All the parts I receive are just Kioti parts in Kioti packaging . Cub Cadet has the part number DD T4620-38032 because it goes on the Cub Cadet 8454, which again is just a DK45.
   / Hydraulic Filter
Thank you for the help.
The DK series tractors list the same hydraulic filter as the DS series.
I have a Cub Cadet dealer closer to me than the closest Kioti dealer and the information on their parts is most helpful. The same is true for the NAPA and WIX dealers but even they would have to order the oil, air and fuel filters.
Mail order is a possability but it is better to have it close to home.
Will keep you posted on how it all turns out.
   / Hydraulic Filter
According to the dealer, the 8000 series Cub Cadet never made it to Canada.
My Kioti dealer said that Kioti want you to use their hydraulic filters.
Mail order is probably the best option.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
