Down side of magnets is that can cause the smaller fuzz like particles to clump together and then get flushed down stream from a flow surge. I have seem them used on suction strainers but never on a pressure or return line filter.
Like HarryE stated,
Magnetic plugs are very common on gear boxes where no filtration is present.
Magnetic circuits are what I did at work, so I have some knowledge if anyone has questions. Although this posting might just be redundant as I agree completely with what MHarryE and OldnSlo just said.
If you add magnets, think it through carefully. Having one on the intake surface of the filter isn't going to do much. Anything that makes it there is caught anyway. Having a magnet on the other surface of the filter - the surface where the cleaned oil returns to the system - is pointless as the filter has already caught and removed particles of a size to be a problem.
As for those large curls of metal - I think we've all seen them and they frighten me too. It seems so "unKubotalike" not to flush the cases better. But what about all those the smaller chips? Take a look under magnification and see if you agree that some have crushed edges that look like they were squeezed off of a larger chip. Maybe during machining; maybe not. About half of them are blued from heat....what's that all about?
There used to be a line of aftermarket drain plugs that had magnets potted into the inner ends where they could pick up particles directly from the oil. BTW, simply placing a magnet on the outside of the drain plug does nothing. The idea of the aftermarket magnetic plugs with the internal magnets was that you would wipe off the fuzz when you pulled the plug out. Sure enough, they were often coated with fuzz. Cleaning them made me feel good, and I think there's a benefit there - but only if you pull the plug a lot because there's a problem that could happen when enough fuzz accumulates to saturate the magnetic field. In magnetic saturation, new particles attach to the fuzz ball at the expense of old ones which are knocked off - now free to circulate as little magnets themselves able to attach themselves anywhere they want and not be flushed through to the filter and removed.
After a lot of thought, I'm not in favor of the magnets unless they installed so that they can be serviced quite often - more often than one would normally change the oil.
To my mind it makes sense to change the filter more often than recommended in the first few hundred hours. I changed mine at 20, 50 and 100 hours. The oil itself is expensive, but it is easy enough to clean and reuse it several times.
luck, rscotty
