hydraulic filter location
   / hydraulic filter location #1
darwyns
Hockley,Texas
my ym165 3 point hitch is not lifting right only when i open valve under seat with throttle at approx 2000 rpm will it attempt to lift . i was wondering where the hyd filter is located . also what type of fluid goes into the transmission and hydraulic system thanks
   / hydraulic filter location #2
The oil is a JD303 compatible oil. The screen is located directly behind the 3 bolt plate that connects your suction (big) line to the transmission.
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / hydraulic filter location #4
Location of the hydraulic filter for YM 2210? Thanks
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
CAT Skid Steer (A50322)
CAT Skid Steer...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
1265 (A50490)
1265 (A50490)
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
