Hydraulic filter location on mitsubishi mt372d tractor
   / Hydraulic filter location on mitsubishi mt372d tractor #1
slappyhoeman
Where is the hydraulic filter located on a mitsubishi mt372d tractor? lift works fine when starting out but gets sluggish and jumpy the longer it runs. hydraulics and trans share 80w gaer oil?
   / Hydraulic filter location on mitsubishi mt372d tractor #2
Re: Welcome to the Hydraulics Forum!
it is on the lower right side of the case. it is a semi oval/diamond shaped plate with two bolts. be ready with a bucket though. Also I was told that something was lost in the translation with the 80w gear oil. I was told to use a universal hydraulic/trans fluid by a repair shop.
   / Hydraulic filter location on mitsubishi mt372d tractor #3
I use UDT also and it has done fine for several years, yea the filter is a mesh screen, easy to clean.
thanx for the info. didn't know anything about the universal trans/hyd fluid. was told the 3 point was designed to work with 80w gear oil but implements like loaders would not(i don't have a loader). what is a good quality trans/hyd fluid,what's the cost and where can it be purchased(at auto parts store or tractor dealership)
   / Hydraulic filter location on mitsubishi mt372d tractor #5
Wal-Mart, Rotella tractor hydraulic oil in the automotive section.
Mystic in the blue pail, purchased at most tractor stores and several auto parts stores.
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
Ford 641 Workmaster (A50514)
Ford 641...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
(4) 12-16.5 NHS TIRES & RIMS (A51243)
(4) 12-16.5 NHS...
