Oil & Fuel Hydraulic Filter Cross Reference
   / Hydraulic Filter Cross Reference #1
Tractorsearch
I no longer have a local dealer for my Century 2535, does anyone have a Hydraulic Filter Cross reference with other tractor/truck part manufacturers?
Also, I have an issue where my hydraulics are weaker than they used to be and the backhoe has a tendency to drift down during normal tractor use. I think it might be a leaking (internally) valve but I have no clue how to even begin to diagnose....any ideas?
   / Hydraulic Filter Cross Reference #2
Wix 51202??? Pretty common filter.
Wasn't Branson tractors also Kujke? If so, you might find that Wix number to be the one. Double check though.
I believe my Century 2535 is a Kukje.
   / Hydraulic Filter Cross Reference #4
Kukje = Branson = Century
Kukje is the South Korean manufacturing firm that makes both the brands of tractors.
Also said:
Any ideas on this? I was told that there is an internal pressure bypass valve internal to the hydraulic system but I do not know where or if that could be the cause. BTW, the rear arms have a tendency to drift downward when under a weight load also.
   / Hydraulic Filter Cross Reference #6
The 3 point losing height under load is most likely the seals on the rockshaft piston. I had the same issue finally had to tear it down to find the problem. Both the u seal and backer were blown smooth through andwould not hold pressure. Waiting for parts to arrive, bout', $40. I did learn after teardown I coild have reomved just the front of the assembly while on the tractor and saved lots of R/R time. Good lesson though. My problem did not affect the FEL though, just the 3 point. Good Luck.
   / Hydraulic Filter Cross Reference #7
cross refernce number for hydraulic filter for 4340 zetor
   / Hydraulic Filter Cross Reference #8
Here is the website to cross ref from other filter numbers and by vehicle - Yes they do tractors and equipment as well...
This is for Wix, and if you don't like Wix - at least you will have a Wix number to cross reference with another brand...
WIX Filters - Products Catalog Home
   / Hydraulic Filter Cross Reference #9
From the above listed web site - a lookup provided the following:
All filter numbers are Wix
Oil: 51243
Fuel: 33112
Air: 46376
This site does not have the hydraulic filter listed at this time
   / Hydraulic Filter Cross Reference #10
I just called WIX and they do not make a cross-reference Hyd filter for my 4820R tractor.
The correct Branson , 4820R cartridge Hyd filter # is: TA00025525C per a dealer parts desk, the HST 20 series requires two hyd filters
2014 MACK CXU (PINNACLE) (A45046)
2014 MACK CXU...
2007 MERTZ FRAC BLENDER TRAILER (A45333)
2007 MERTZ FRAC...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2016 INTERNATIONAL...
264 Gallon IBC Tank With Drain Valve (A42745)
264 Gallon IBC...
Solo Rider Golf Cart (A42745)
Solo Rider Golf...
Honda FRC800 Walk Behind Tiller (A44502)
Honda FRC800 Walk...
