Hydraulic fill JD 3320?? HELP :)
   / Hydraulic fill JD 3320?? HELP :) #1
Bigdoggie
Foster RI
Looking 3320
Hello,
I have a JD 3320 with the back hoe attachment. I blew a hose yesterday, I am going to get the new hose made now. Not sure where to check and or fill hydraulic fluid.
Need to know:
WHere to check
Is there a stick or is it fill to spill like oil in a generator
Can I use any hydraulic fluid or do I need something special??
Thanks in advance!!!!!
   / Hydraulic fill JD 3320?? HELP :) #2
Standing facing the back of the tractor there is a dip stick above the left axle. It's hard to read the clear oil. The fill is located above where the top link attaches to the tractor kind of behind and under the seat. The yellow cap. I use a gear oil pump with a hose because it is tough to get to. As far as the fluid I use the low viscosity John Deere hydraulic oil. All of this is in the owners manual.
Dan
Genie GS-1930 (A50120)
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2014 Ford Transit Connect Van (A50323)
2014 Ford Transit...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A50322)
2017 Toro Z-Master...
Hoemann Tire Balancer (A50121)
Hoemann Tire...
