Hydraulic fill cap
   / Hydraulic fill cap #1
fishfrank
Has anyone come up with a replacement for the red plastic hydraulic fill cap? Mine is on a DK40SE. I noticed it allows dirt and junk to come in through the vent hole.
   / Hydraulic fill cap #2
Put a sock over it? Or a piece of hosiery? Or a cigarette filter with a slightly enlarged hole? Or...
   / Hydraulic fill cap #3
have a looks at this link Parts Finder Nolt's Power Equipment LLC Shippensburg, PA (717) 423-63
This is typically for a DKse tractors backhoe attachments. This allows return oil to return down the fill tube via an added quick disconnect. The original remote valve return proved too restrictive during prolonged use, which caused overheating. But also notice the new vent that is added (because the female quick disconnect will take place of the old vent). This bolt hole leads to the transmission case, so part 31351-37142, BT664-83000, and BT664-82000 are added to create the new vent.
If this S-type of vent seems better to you than the original fill vent, it would be a pretty cheap to order just those parts, and then plug the hole in the fill cap.
Another solution could be to drill and tap a small breather filter on top of the fill cap. something like this. uxcell 5 Pcs 1/8" Thread Sintered Bronze Pneumatic Exhaust Silencer Muffler: Industrial Air Cylinder Accessories: Amazon.com: Industrial & Scientific
LED Peterbilt Sign (A50324)
LED Peterbilt Sign...
2014 Chevrolet Cruze (A51694)
2014 Chevrolet...
2025 Kearney 102"x36' Trailer (A50120)
2025 Kearney...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Propane Tank (A50121)
