Hydraulic education
   / Hydraulic education #1
Tig
Veteran Member
The County, Ontario, Canada
Kubota, B7100HST-D
Inspired by all the wonderful projects I see here I would like to do one of my own. As they go onsale I am collecting the parts that people here have used. While trying to do this I realize how little I know about hydraulics. :confused: I don't understand most of the terminology. Can anyone recommend a web site with explanations of hydraulic terms, circuit and maybe how to read a hydraulic scematic. Right now I am looking at a 2 way 3 position selector valve to use in a two cylinder top & tilt. It's cheap, but I don't think it's power beyond. Thanks.
Steve
   / Hydraulic education #2
To add a TNT setup to your B7100 you are going to need at least a 2 spool open center valve with power beyond. I am not sure what selector valve you are looking at. You can probably use the Eaton-Cessna valve from Surplus Center if your pump flow is under 5 gpm. Cheap isn't always the way to go. You need to get what will work. There are literally hundreds of posts that discuss adding rear remote hydraulics to tractors.
To get a basic overview of how hydraulics work look HERE.
Thanks for the link. I also found Hydraulic Tutorials
It's probably a spool valve I want in the first place and not a selector valve. I've read many of the top & tilt threads. I'll re-read them once I understand hydraulics better.
   / Hydraulic education #4
The US army has training material that is not copyright. You can find guys on ebay that sell a CD of the manuals for $5 or so, or you can search Google and possibly find the material in an ROTC website for free.
Good luck with your projects.
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
(3) Air Hose Reels (A51573)
(3) Air Hose Reels...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
