Oil & Fuel HYDRAULIC DRAIN PLUS CK30 HST
   / HYDRAULIC DRAIN PLUS CK30 HST #1
DIRTCUTTER
New Mexico
CK30 HST
How many drain plugs on a ck30 hst for hydraulic fluid. ?
   / HYDRAULIC DRAIN PLUS CK30 HST #2
One on each lower axle and 1 main? IIRC..
   / HYDRAULIC DRAIN PLUS CK30 HST #3
I Concur :thumbsup:
   / HYDRAULIC DRAIN PLUS CK30 HST #4
Me three. The plugs at the finals only drain a small bit of fluid. The big dog in the middle has lots of fluid above it. I recommend doing the finals first as a means to reduce the pressure behind the big dog.
   / HYDRAULIC DRAIN PLUS CK30 HST #5
To add on to what Highbeam said, draining one of the rear lowers first, will reduce the amount of initial flow (unless you want to put your hand into the outflow stream to replug the big sump before your drain pan overflows) and reduce the chance of your having a drain pan overflow. Even when draining the rear first, you need a big drain pan. I think mine is 5 gal, and it gets as full as I like it for purposes of pouring the oil back into a 5 gal waste oil pail.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
Kubota B7200 (A50120)
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
John Deere 7810...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
