Hydraulic cylinders
   / Hydraulic cylinders #1
alaskanjdeere
Bronze Member
Wasilla Alaska
SCOTTS 2554 & JD 4410, x744
I'm in the middle of a TNT project and have a question about the fluid. Do I have to add fluid to the rams and valve before I attach them to the tractors system? Does the air need to be bleed? Or do I just add fluid to the tractors main tank and cycle the valve and not worry about it? I'm tying into my power beyond hose with a four section valve with a total of three 2" bore cylinders (2-12" and 1-8" stroke). Thanks for any help Shawn
   / Hydraulic cylinders #3
There is no need to bleed the system, the air will find its way out on its own...just start moving levers around, then check your fluid level.
   / Hydraulic cylinders #4
Thank you Kennyd
I wasn't sure so thought I better ask. Shawn
Thank you Kennyd
   / Hydraulic cylinders #7
It will bleed out faster if you hold the control with the cylinder all the way in for a couple seconds (you will hear the relief valve operate and the pump will get noiser as they air hits it) then all the way out and hold it. Do that 5-6 times and you should be good to go.
jb
   / Hydraulic cylinders #8
jb
2002 Sterling M7500 Acterra Lift-All LA04C51 51FT Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
Bobcat 15 Skidloader PHD (A50774)
Bobcat 15...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
