powerscol
Veteran Member
I am trying to choose the correct cylinder for my sickle mower lift conversion. From another post I know the dimension and brand previously used and I confirmed the movement and fit on my mower today using a pvc mock up . Its a Tractor Supply unit rated at 2500 PSI
From my Bobcat owners manual it states System Relief at quick couplers is 2611 psi.
From this information will this cylinder work, or do I need to find one rated for a higher PSI? They do exist through several sources.
Also it appears the hoses I need should be rated at 3000 psi or higher, correct?
Thanks from an old guy still learning.
