Hydraulic Cylinder Seals
   / Hydraulic Cylinder Seals #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I have to replace the seals in one of the lift cylinders on my JD loader. I think it is due to lack of use. I was using it the other day for the first time in a while and it started leaking. Would it be a good idea to replace BOTH lift cylinder seals at the same time?
   / Hydraulic Cylinder Seals #2
Absolutely do them both. BTW, if the leakage is from lack of use, use it, get the oil good and warm, and the seals may swell back to size and seal. Anyhow, when you only do one cylinder, the other side may be leaking internally. Now, you have good power on one cylinder and less on the other. This will cause your loader arms to always twist. When you have cylinders that work in a pair, always do to one what you do to the other.
Andy
   / Hydraulic Cylinder Seals #3
What Andy said. Do them both at the same time.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
2014 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2014 Isuzu NPR-HD...
Scag Tiger Cat Zeroturn (RUNS) (A50774)
Scag Tiger Cat...
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
