Kernopelli
Veteran Member
- Joined
- Oct 16, 2006
- Messages
- 2,209
- Location
- Carterville, Illinois
- Tractor
- Mitsubishi MTE2000D, Dig It 258 Mini Ex, Deere Z930A ZTR
I have leaking seals on a backhoe cylinder and can not get the gland nut loose. This is the second time I've had to rebuild one of these cylinders and on the first one, the gland nut never came loose......I tried and tried and eventually took it to a local hydraulic shop that does most of the work for local mines and excavation contractors and they ruined the gland nut and still didn't get it out.
I can put enough pressure on the spanner that it will simply shear the pins off in the gland holes ( this is a heavy wrench with treated 1/4" pins). The nut is recessed so I can't get a pipe or chain wrench on it. I am at a loss! I have tried heating, turning both directions, tapping with a hammer and penetrant to no avail. The nut is aluminum and the barrel is steel. The nut has 2 holes for spanner pins, I am considering drilling 1 or 2 more holes and making a 3 or 4 pin wrench to get more "bite" on the gland.
Anyone know a secret or have a better idea than a wrench with more pins?
