Hydraulic Cylinder Leak at Nipple Bottom of Cylinder
   / Hydraulic Cylinder Leak at Nipple Bottom of Cylinder #1
landrand
Bronze Member
Ishpeming, MI
Internation 674, John Deer 6400, Kubota BX2670, Ford New Holland 655D
I have a Ford/New Holland 655D backhoe and one of my loader hydraulic cylinders is leaking oil. As shown in the attached picture, there's a small outlet nipple protruding from the bottom of the cylinder and oil is dripping from this outlet when the backhoe is running. Since I know very little about hydraulics, would anyone be willing to provide advice on how I should go about fixing this leak. I would assume that an internal seal is bad and needs to be replaced. Is this fix something that a novice could repair or should I bring the cylinder to a professional and have it done? Thanks for your time! View attachment 654881
   / Hydraulic Cylinder Leak at Nipple Bottom of Cylinder #2
That nipple is a round lock wire sticking out. The oring and backup under that hole in the barrel is leaking, likely from a rust ring at the oring. Time to purchase a new seal kit and repack it yourself if you are capable or farm it out to a local mechanic, tractor shop or hyd shop.
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
UNUSED X-STAR 8' X 40' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 8' X...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2021 JOHN DEERE 1725 CCS LOT IDENTIFIER 29 (A53084)
2021 JOHN DEERE...
UNUSED FUTURE ELECTRIC MASSAGE CHAIR (A51248)
UNUSED FUTURE...
