davedj1
Veteran Member
I was just searching Ebay and stumbled across a hydraulic unit (3phase powered) and it lists the cylinder as 750lbs. The cylinder I have came from a furniture mill and had an electric hydraulic unit powering it. I'm afraid if I hook this thing up to a 22 gpm pump with 2500-2750 lbs pressure I may have a potential missile on my hands. Is there anything I can look up to see what type/pressure cylinder I have? There are no markings on the cylinder, all I have are the dimensions.
Specs are: 4.5" bore
1.75" ram
30" stroke
the mounting clevis is huge with a 1 1/8" pin, the pin on the other end is the same size.
The place where my cyl came from built and steamed furniture parts, the cyl was used in a verticle position on a press.
thanks for any help
dave
that steel plate attached is 1" thick.
1.75" ram
30" stroke
thanks for any help
dave
