Backhoe Hydraulic Cylinder for Kubota K-650 Backhoe
   / Hydraulic Cylinder for Kubota K-650 Backhoe #1
handymansvs
Hello Everyone,
On the Kubota K-650 Backhoe I recently acquired, the Dipper(Crowd) Hydraulic Cylinder was damaged. I pulled it off and took it to a local reputable hydraulic repair shop. I learned this afternoon it would most likely more expensive to repair the cylinder then to buy a new one as the Rod is bent and the inside of the Barrel walls are scored.
I am faced with several problems. The first is I have been unable to find a Parts or Service Manual for the Kubota K-650 Backhoe with enough detail. The parts numbers listed are a dead end. I was able to establish the Amerquip (Arps Corporation) built the backhoe for Kubota, however they no longer had any manuals or part specifications as it has been 30 years +/- since the K-650 Backhoe was built. For those reasons, I believe my only alternative is to purchase a new replacement cylinder.
My knowledge of hydraulic system and hydraulic cylinder is very limited, so I need a good solid supplier that can advise me about my options. Specifically, I need a reference for a good hydraulic cylinder supplier in the Portland, Oregon and surrounding area(25 mile radius).
I appreciate any and all referrals.
Respectfully,
Benjamin J. "Joe" Browning
handyman@iinet.com
   / Hydraulic Cylinder for Kubota K-650 Backhoe #2
You might try asking TBN member myyaz33, he posted in the past about that particular backhoe and stated he had a parts manual for it. At the very least maybe it will show the cylinder dimensions so you can order something similar from a place like "Surplus Center." Good luck.
Hi Bud,
I was not able to find a Kubota Hydraulic Cylinder! I tried Harbor Freight, however several cylinders were close, but off just enough that they would not work. I contacted the original Machine Shop that I had taken the damaged cylinder to have fixed. We were able to find one that was a perfect fit for $180.00 plus freight. Total cost was half the repair price.
Thanks again, Joe
   / Hydraulic Cylinder for Kubota K-650 Backhoe #4
All's well that ends well, glad it worked out for you.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
