Hydraulic coupling types
   / Hydraulic coupling types #1
Sheena
I have an old Ford 1200. I want to get a log splitter to hook on 3point system but am having trouble identifying the original hydraulic coupling fittings on the back ? Any idea what size and type came fitted to the Ford 1200 ?
Really could do with some help on this many thanks in advance.
   / Hydraulic coupling types #2
Unscrew the QD fitting and take it with you to the hyd supply for a match up.
   / Hydraulic coupling types #3
There were a variety of suppliers used over the years. JJ's suggestion is good because you want to make sure that the shoulder dimension matches. That would be the distance from the retaining balls (and the mating groove of the male end) to the poppet tip of both parts to ensure that an open passage is created when the two halves are joined.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2021 Simex TFC 400 rotary cutter, like  new (A52384)
2021 Simex TFC 400...
2014 John Deere 644K Articulated Wheel Loader (A51691)
2014 John Deere...
2010 Cadillac CTS Sedan (A51694)
2010 Cadillac CTS...
