Hydraulic Coupler and fitting question
   / Hydraulic Coupler and fitting question #1
Mike_VT
Vermont
Kubota L4740 HSTC
Just purchased a grapple that has 1/2 #8 fittings on the hoses. I plan on using the rear remotes on the tractor to run the grapple claw. The female quick couplers on the tractor remotes are pioneer 4050 3p (3/8 poppet style) So I plan to run hoses from the rear to the front. The trick is when I get to the front. Does anyone know if you can you mate a 4050 3p (3/8) female to the 4050 4P (1/2) male. I was told that the actual coupler i.d and the nipple i.d. were the same size??? My goal would be to have all the stuff consistant Any advice would be great. Mike
   / Hydraulic Coupler and fitting question #2
The 4050 4P and the 4050 3P are definitely different sizes, and can't be mated. You'll have to put 1/2" couplings at the "front" ends of the hoses to mate with the couplers on the grapple.
Alternatively, you could replace the couplings on the grapple with 3/8 QDs; I doubt that the cylinders on your grapple require the higher capacity of 1/2" fittings. I have a WR Long grapple on my JD4520, the JD plumbing down the loader arms has 1/4" 4050 2P (1/4"), and it is plenty quick when opening and closing.
Tom.
Thanks. appreciate the help. Did some research and will be untilizing an adapter: 1/2 femal npt to 3/8 male npt to the 3/8 qucik attach. I will be buying from discount hydraulic hose it seem they have the best prices and is far less expensive than the local dealer. Mike
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Pallet Fees (A50775)
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52748)
2018 Rock Solid...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
