Hydraulic Control Repair/Replace
   / Hydraulic Control Repair/Replace #1
DeadTurtleCreek
NW Mississippi
JD 6415; Mahindra 7060
I really have 2 questions. They may need their own threads, but we'll see how it goes.
I have a Case 95C with a lever that moves the 3pt hitch. The lever is burdensome and difficult to use well when trying to do any precision work such as grading. I also use a JD6415 that has a roller to control the 3pt hitch instead of a lever. That roller control is awesome and can move the hitch easily with just a swipe of a finger. Is it possible, and how feasible would it be to convert the Case 3pt lever into a roller control like the JD has?
2nd question; That JD has 2 rear remotes which have been giving me trouble hanging up. I'm not sure of the term for it, but if you push the lever all the way forward it will lock into place running the hydraulics continuously. Normally a little pressure pulls it back to disengage but it has been getting locked into place very firmly recently. Previous threads seem to have fixed this issue so I will try some of those options. But the real question is, is it possible to also add some type of roller control to these remotes? That would add a greater level of precision as well as make it much easier to use without full effort.
Thanks for your help.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A52705)
2024 ATLAS CORPO...
