Hydraulic Connections, Plug & Caps
   / Hydraulic Connections, Plug & Caps #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All.
I just bought a B3000 with a front mount snow blower B2782B.
I went out to grease things up and noticed that it is missing several of the Hydraulic plugs and caps for the Hydraulic connections/couplers.
The inside diameter of one of the female fitting appears to be 5/8" plus/minus, but I believe everything that Kubota does is in metric sizes.
I want to purchase several caps and plugs as I want to assure those connectors remain as dirt free as possible.
Anyone know what the size is that I need? Both for the plug and for the caps/covers?
Is it the same size for ALL of the fittings Kubota uses for all of their implements?
I wonder if they sell a "kit" full of coupling protectors.
Thanks for any assistance.
   / Hydraulic Connections, Plug & Caps #2
Tim,
As far as I know, all Hydraulic connections/couplers are made to an ISO standard. You should be able to find covers/proctors at most Ag supply stores.
Thank you for the info gentlemen.
I think I'll try my luck at Tractor Supply. There is one about 10 minutes away from me.
Thanks again.
   / Hydraulic Connections, Plug & Caps #5
I have seen caps & plugs that are color coded so you can match up the hoses and connectors easily. However, I have not been able to locate a source.
   / Hydraulic Connections, Plug & Caps #6
Hi All.
try discounthydraulics.com
   / Hydraulic Connections, Plug & Caps #7
Hi All.
Amazon has what you need. I am pretty sure you have 1/2 AG couplers also known as ISO 5675
Follow this link
Robot Check
Hi Dale.
I have seen them too. I'll keep searching for a source.
Thanks.
Follow this link
Robot Check
Hi Motorboatin,
Thanks for the info.
I'll check out Amazon too and compare prices with the other suggested places.
I appreciate the info.
Regards.
Cherokee camper trailer (A51694)
Cherokee camper...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
