Front-End Loader Hydraulic connections on L2550 and LA650A
   / Hydraulic connections on L2550 and LA650A #1
Morgan L2550
York PA
Kubota L2550DT
Is there a diagram somebody can post on where to hook the two hydraulic lines that come off my loader to the tractor?? Down on the lower right side of tractor is a Hydraulic junction block of sorts. It has 3 steel lines entering it on its left side. There is a flexible line that loops two connection points together on its face and then there is a single quick disconnect fitting off its right side. Nothing labled of course. I have three lines hanging off the loader valve assembly. One that butts straight out towards the driver that has a green band around it and a green dot at the fitting it connects to on the valve assembly. I am guessing this is an aux line???? Then of course I have the other two lines hanging off. I am sure one is high pressure and the other is the suction line/ return line. So far I have not read anything online here about what lines are for and connections to make things work. Surely I am not the first guy to hook a loader up in his driveway:thumbsup:
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
