hydraulic cables connection problems
   / hydraulic cables connection problems #1
sabaka33
I have a cat228 that I've been having problem with lately.
the hydraulic cables required to connect attachment are sometimes impossible to attach. Looks like they are under pressure, and I'm wondering why this happens. /forums/images/graemlins/confused.gif
can this be avoided? or does it require repair/replacement?
any help appreciated /forums/images/graemlins/smile.gif
   / hydraulic cables connection problems #2
Shut the machine down and work the lever or whatever to that set of hoses. That will relieve the pressure. If that doesn't work. Use something round to push in the ball on the end of the connector and be prepared to get squirted unless you wrap a rag around the fitting.
2013 Ford Fusion Sedan (A51694)
2013 Ford Fusion...
2003 Ford E-350 Cargo Van (A51692)
2003 Ford E-350...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2008 Ford F-250 Crew Cab Pickup Truck (A51692)
2008 Ford F-250...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
