Hydraulic breaker
   / Hydraulic breaker #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Yea, I know, it breaks things apart, but
Does anyone know for sure how these things work? I am thinking it is operated by some kind of valve that interrupts the hydraulic fluid, at a certain receptive rate. Has anyone ever seen one of these valves? If so, what does it look like, and any idea where to get them, and the cost. Could it even be a type of shuttle valve, or electrical impulse to a coil on a hydraulic valve. I have heard the term, butterfly valve associated with hydraulics. I sure would like to know.
   / Hydraulic breaker
Come on guys. Surely someone knows the name of the device to cause a hydraulic cylinder to pulsate like in a hydraulic demolition hammer. Whatever is on those tree transplant rigs to push the shovels in the ground.
   / Hydraulic breaker #3
If you are talking about a breaker for concrete or rock there is quite a bit more to it than just a valve The head or top part of them are full of shuttle valves and different ports for the oil machined in to them also most of the use nitrogen to cycle the hammer and help keep the shock load off the hydralic system. At least that how the Allied that we sell and service are along with some of the other brands that i have repaired over the years
   / Hydraulic breaker
Thanks. Do you know anything about the valve that vibrates the shovels on the tree diggers. Some of the shovel blades just push down, and others I have seen vibrate down. Tree trans planters.
   / Hydraulic breaker #5
not sure about them but i would think they work about like a shaker for truck beds all that is a excentric on a shaft run by a electric motor the plate tampers we have work the same way only a hydralic motor drives the excentric
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Ford Tractor (A50120)
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
