JimMorrissey
Veteran Member
Does anybody have any experience with the capabilities of a hydraulic hammer on a skidsteer or a small TLB? I'm thinking about a hammer that weighs around 300lbs or so.
Reason being......I've got this large cistern that is a nightmare to break apart. -Used hammer drills to cut into it and then beat with a large sledge, I've rented a big jack-hammer and had-at-it for half of last Saturday and all of Sunday with lots of pain and minimal results. It's very old and extremely hard concrete full of rocks and steel. I also have lots of large rocks (boulders) that are going to be a problem when trenching for my electric lines and the sewer line next year.....I'd like to fracture these boulders so they are more manageable. It's also possible, although unlikely, that I will run into some limestone ledge while trenching for the sewer line.
Is a 300lb class hammer capable of breaking limestone within a reasonable amount of time? I'm certain it could given enough time, but I don't want to spend forever on this....OR, am I wasting my time with a hammer in that class.
I could rent a large excavator with a big hammer for about $800 bucks a day plus trucking....figure three days would be about $3200 +-, plus the loss of vacation time. I could buy a good used hammer for that $ on Ebay. It would certainly take a bit longer, but I'd have the breaker and more importanly, be able to work on the project as time allows.
I'm working on the hydraulic plumbing to the stick now and would fabricate a quick-attach plate to bolt the hammer to and be able to easily snag it with the hoe when necessary.
The other option is: Rent a bobcat style breaker for the quick-attach loader. Since it's attached to the loader it won't be nearly as versitile, since you need to be directly over the object. Thinking about it, I guess this would be the ultimate test to see if a breaker of this type would do the job.
Any experineces would be helpful.
