Zephrant
Hydraulic 5' blower on a JD 2210?
I've got a chance to get a 5' hydraulic blower for a decent price, that was designed for a skid-steer. I'd like to convert it to run on my CUT.
I'm thinking that I can put a PTO driven hydraulic pump on my mid PTO, along with a PRV, then install a reservoir/filter on the back of the blower and run lines up to it. I'd use solenoids to control the chute, and run a wire back to the FEL post.
Similar to this one by Erskine:
The idea is that I could change from my bucket to the blower very easily- pull the pins and drop off the bucket, pick up the blower, install the pins and hook up the hoses. My 3PH would have a sander on it- either PTO driven or if I can't get the pump to fit my mid PTO, I'd mount it on the rear and change to a hydraulic sander on the 3PH. I also like the thought of a hydraulic drive on the blower- just a PRV on it for protection, no belts, chains or shafts to deal with.
My blower on/off control is simply the mid-PTO engage.
Potential problems: my CUT only does 17HP at the PTO, and the pump is no better than 95% efficient. So I'd be at something less than 16HP at the blower, which is a little weak for a 5' blower.
However I want the 5' width so I can make two passes on my drive way- 5' wide going down-hill to the road, 4' wide coming back up, for a total width of 9'. I don't mind driving slower, but I don't want to make 3-4 passes with a smaller unit on my 1/4 mile drive. I may do some neighbors too, so the in/out and finished is important to me.
If I could fit the reservoir/filter under the CUT where the mower would normally mount, I could leave it on all the time. Then I could also use it for a wood splitter, or anything else I wanted to run hydraulically.
I should also mention that I want to do this partly as a learning experience- I like building my own stuff, and want to learn about hydraulic systems. I'd also like to get a little bigger CUT (more HP) in the next few years, so if this is marginal (but works) that'd be OK for a while.
So what am I missing here- will this work?
