Hydraulic 3pt lift
   / Hydraulic 3pt lift #1
KiotiDave
Advertiser
Dartmouth College/Lake Sunapee Region, west centra
Can't remember
Hi All,
What do you all use as a Hydraulic lift on the right arm of the 3 pt hitch instead of the crank type? Customer want to be able to adjust the level of his grader blade from inside his cab.
I know they have hydraulic top links, but I need the one for the right lift arm.
Thanks,
KiotiDave
   / Hydraulic 3pt lift #2
How about a hyd cyl that at full travel is equal to adjustable link travel connected with a short piece of chain with a clevis on the end.
   / Hydraulic 3pt lift #3
Do a search for "TnT" as is TOP and TILT. Basically a HTL (hydraulic top link) and a HSL (hydraulic side link)
   / Hydraulic 3pt lift #4
You should contact Carter & Carter Machinery in Johnson City, TN. They have been doing this for a long time and have the best cylinders for doing exactly what your client wants. Here's a link and photo.
CCM
2020 KUBOTA RTV...
CASE INTERNATIONAL 12R 30" CORN HEAD (A51247)
CASE INTERNATIONAL...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
