hydralics
   / hydralics #1
croatian
venetia,pa
toolcat 5600
I have a toolcat 5600. I have lost power steering and hydraulic function to lift arm and bed. I think it may be the pump, but am hoping it might be something more simple. Does anyone have any suggestions?
   / hydralics #2
Does it still drive, wheels have power forward & reverse? If it does not drive, then check the drive belt. If wheels turn, then it is likely something in or at the gear pump(s).
   / hydralics #3
It probably has a separate implement pump, so check all the safety locks and then install a hyd gage in the loader circuit and see if you can develop any pressure.
A flow meter gage setup would be the best way to determine pump flow and pressure capability.
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2012 CATERPILLAR 308E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
Roose Hog Cart (A50515)
Roose Hog Cart...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
