hydralics not working
   / hydralics not working #1
hoogy
Chester, Vermont
MF GC2310 HST
I have massey ferguson GS 2300. We got four inches of snow today. started tractor to get rid of snow. Bucket won't come up can't lift snowblower. and rear pto dosen't engage. I know we have had a cold spell but tractor has never done this before. It is stored in a lean too with no heat but it is covered. I usally start tractor then get dressed to go out . Usally about ten minutes. Nothing is working. i can move tractor forward and back but the bucket and snowblower nothing happens. It has been running for about a half hour nothing and still nothing. Outside temp is 18 degrees.
   / hydralics not working #2
It may be water contamination in the hydraulic fluid. It can freeze in the lines/valves.Tomorrow is going to be quite warm, start it up and try to engage the PTO. If it engages , let in run a couple minutes then look at the hydraulic fluid sight glass. If it's milky, then time to change the hydro fluid. The water will separate from lower quality, or used up oil, settling to the bottom, so the sight glass will show clear oil if it has been sitting for a while. Running the PTO mixes it all up again. I wouldn't worry about the pump just yet.
   / hydralics not working #3
i was thinking your problem is what DWM described. Probably have an excess of moisture in the hydraulic oil. You could do a crackle test and it would quickly answer the question for you. Visual crackle test
   / hydralics not working #4
Is your tractor a 2005?
If it is, it sounds like another case of the dreaded hydraulic pump shear.
If you have a 2005, could you please provide the serial number?
A friend looked at my tractor. Said hydralic fliud looked milky. so i drove tractor in garage and let it sit overnight. Started tractor in morning and bucket moved. called dealer and want him to change hydralic fliud. going to also have change all filters and change oil
   / hydralics not working #7
JRA22204 is my serial #
That's good news for you. Looks like you have a 2006.
It' clear your problem is water in the fluid.
2005's can have the same symptoms, which requires an expensive repair job.
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
More info coming soon! (A50323)
More info coming...
