Hydralic pump drive belt problems.
   / Hydralic pump drive belt problems. #1
Groo
Platinum Member
I have a Timberking 2000 sawmill that is eating drive-belts way to quickly. The factory belt was an absolute joke and rated for way less power than it was asked to transmit. The better belts I have been picking up locally aren't lasting the greatest either. I am thinking something has to change.
I am thinking either just getting larger pullies (and a corresponding longer belt) or since I'd have to change over everything anyways, possibly converting it to a cogged or micro-rib belt.
Another idea I had would be to add a spring loaded belt tensioner to keep a more consistent belt tension. Think that would make a significant difference in belt life?
Its a full hydro machine. The stock pullies are about 4.5" diameter and the stock belt is 31"
   / Hydralic pump drive belt problems. #2
Could you go double pulleys?
I am sure the belts are HP limited.
Spring tension would probably help.
Try some Aramid belts. Heavy Duty Aramid Belts
Above a certain HP, it seems they go to cogged belts or serpentine belts.
   / Hydralic pump drive belt problems. #3
Double pulley makes a huge difference . I had to do it when I repowered my tractor from a Cummins to a Cat the pump drove off back of engine in the Cummins app ,the Cat 3208 I had to build a belt drive system and like your system one belt wasn't enough.
oops, I think I typed in in wrong. There are two belts, the blade belt is a double belt, and it is doing fine. The hydro belt is the one that is giving me troubles. sorry if that was unclear.
After a little more research; It looks like the replacement belts I have been getting are light duty belts too. I guess the next step is to move up to a Kelvlar belt.
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2016 Ford Explorer...
2014 Nissan Juke Multipurpose Vehicle (MPV) (A51694)
2014 Nissan Juke...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
