Oil & Fuel Hydralic Leak
   / Hydralic Leak #1
Joe Lemons
Vicksburg MS
Massey Ferguson 230
I have a MF230 that has developed a bad leak, think it is hydralic fluid. When I look under the tractor in front of the rear tires there is a cover that has a cotter pen that it looks like it is designed to pass fluid. If I take the plate off is this something I can fix myself by removing a part and having repaired or fixed? Or should I load up and take to a mechanic?
   / Hydralic Leak #2
Don't know that tractor but it sounds like a air vent. Check your fluid levels, it could be just over filled or it could be water getting into it. Fluid levels should be way below air vents.
   / Hydralic Leak #3
That cotter pin in a hole is designed to keep the hole clear to allow fluid to drip out.
Usually found bottom of bell housing on clutched tractors.
Over fill is one possibility but another is a damaged oil seal that allows leakage.
Checking fluid level is best bet and there is always the possibility that what you see is a longtime accumulation that simply suddenly decided to 'let go'.
If the fluid level maintains itself reasonably well, just live with it.
If it is hydraulic fluid then you actually have a lot in there B4 you cause damage, and besides the FEL will starve when it gets too low without creating serious damage. (FEL equipped tractors generally share the transmission fluid hence a lot in there)
The concern would be if you are hydrostatic as starving the pump could prove costly.
2010 Toyota Corolla LE Sedan (A50324)
2010 Toyota...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
