hydralic fluid ISO. what's the difference.
   / hydralic fluid ISO. what's the difference. #1
swapwap
augusta, ga
82 powerking
hydralic fluid ISO. what\'s the difference.
I have a leak on my FEL, I called the dealer and asked them what type of fluid I could put in it until they can gt the parts ordered and come out and fix it. He told me most any good quality hydralic oil will work, SO I found some ISO 32 oil AND PUT SOME IN. After I got some bush hogging done, I decided to read up on it. I've fould several type that should be comparable to the super UDT, such as:
Amsoil Synthetic Tractor Hydraulic/Transmission Oil (ISO 46)
Chevron Synthetic All-Weather THF (ISO 46)
Citgo Low-Temp Tractor Hydraulic Fluid (ISO 37)
Esso Hydraul 50 (ISO 32)
Esso Hydraul Extra (ISO 43)
Mobilfluid LT (ISO 42)
Petro-Canada Duratran Synthetic (ISO 47)
Schaeffer #315 Simplex Supreme Synthetic Blend (ISO 54)
Shell Canada Donax TDL (ISO 32)
I live in the south and have a 7510. What ISO would be best for me to use? and since I've already mixed fluid should I drain and refill with just one? thanks
   / hydralic fluid ISO. what's the difference. #2
Re: hydralic fluid ISO. what\'s the difference.
I guess the big issue is .. do you have a seperate hydro system.. or is your hydro system and tranny/diffy all one sump.. If all one sump.. I'm betting it specs utf.. etc.. if it is just a hyds sump.. I imagine yout aw32 would work.. your dealer said it would. Whats the manual say.
Soundguy
   / hydralic fluid ISO. what's the difference. #3
If it were leaking badly and I needed the tractor, I'd use R&O at $15 a bucket until it was fixed. /forums/images/graemlins/tongue.gif If tractor's a hydro, and has one sump, then I'd use the good stuff.
Anyway, I=international S=standards O=organization
The number is the viscosity at 40C
letters before the # are for physical properties like AW=antiwear, VG=veg base and so on
For your clime ISO32-46 is best for seperate system
Usually an AW oil would be for shared systems where hyd oil lubes transmission gears etc.
manual says kubota supet udt. what's the difference inthe iso's?
   / hydralic fluid ISO. what's the difference. #5
Maybe best asked on Kubota forum, Bucket or jug of the super stuff shoul label the ISO and give a letter to denote physical properties,One that would need to be paid attention to is if it is synthetic and able to mix with petro based oil. I imagine it would denote that in wording also. I don't use synthetic, but I believe theres a lettering system that correlates with an ISO#
   / hydralic fluid ISO. what's the difference. #6
If your manual specs UDT / UTF.. then I sure wouldn't be putting 'jack oil' in it.. ..
Soundguy
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A51692)
2017 Ford F-350...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
New Holland B95 Backhoe (A50490)
New Holland B95...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
