Hyd.system test
   / Hyd.system test #1
scotty088
Bronze Member
Warren,Oregon
Kubota BX 2230
I see BXpanded sells a hydraulic system test/adjust kit for the BX series tractors.How often should this test be ran.What would cause the hyd.system settings to change.My tractor works just fine with 450 hrs on the clock.Should I have it checked?Any advice will be appreciated...As always thanks for your expertese.... Scotty
   / Hyd.system test #2
Certainly test it when new, but after that, only when you are trying
to debug a problem. Or maybe once every 10 yrs, if you are looking
for things to do. If everything works OK, don't worry about it. When
a tractor get old, I suspect the RV springs may get a little less springy
(tired), so the pressure drops.
I have seen as-delivered pressures to be WAY off on tractors, hoes,
and valves.
   / Hyd.system test #3
It is just a piece of test equipment to monitor or test your hyd system. Use it whenever you think things are not right, or to keep up with the wear and tear on the hyd system. It is one of those things that all tractor owners should own or make. It even comes with shims for those valves that use shims.
   / Hyd.system test #4
dfkrug had a great thread about pressure on a new tractor. That's a great place to use a kit like the one you saw. Other than that, just like stated, probably only used if you are trying to find the cause of a problem.
8ft Forklift Safety Basket Attachment (A51691)
8ft Forklift...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2024 78in Screening Bucket Skid Steer Attachment (A51691)
2024 78in...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
