Hyd Steer Help
   / Hyd Steer Help #1
kioti79
Manchester Ia
John Deere 455
I have searched a few threads on here, but haven't found the info I need. I have a John Deere 455 All Wheel Steer. Like alot of people found out the steer cylinder is welded. I am fairly good with metal and have the cylinder apart. I can't find any numbers on the seals or where to get seals. Can anybody point me in the right direction? Thank You in advance and hope to repay the favor.
   / Hyd Steer Help #2
probably what you will learn on this adventure is that those seals are probably proprietary to john deere, also if the cylinders are welded they were meant to be replaced not repaired, that being said, you have a few options replace them, but that won't be near as fun as the other two options. you may be able to go to your nearby hyd. repair shop and try to have them match up something and get lucky, or you can have them made we use american high performance seals here in sw pa,you can either use them or someone comparable in your area. but be fore warned it can be pricey. if you have to go this route i would get the cylinders lead time and price quoted. and due the same with the seal mfg. they will probably want your seals and some metal dimensions before they can quote. hopefully you will get lucky first.
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
