hyd pressure
   / hyd pressure #1
bobcat7532010
Need to release hyd pressure tried turning the key back did not help. This in on a 753
   / hyd pressure #2
Can you explain a bit more. Release for what reason?
   / hyd pressure #3
I have tried turning the key backwards, pressing a button, turning off the skidsteer and it never seems to help. Most of the time the pressure is in the hoses of the attachment and not on the skid steer. The best solution I have found is to unhook your attachment hoses after running the machine when they are hot. Otherwise, crack open a fitting to release a little oil.
Newer bobcat skid steers have different connectors that allow the pressure from each attachment hose to be released before disconnecting. Each coupler is depressed before unhooking hoses. These work much better than the standard couplers found on most skid steers.
   / hyd pressure
I guess to explane more-- I need to hook up a dozer blade and cant because there is pressure in the fittings either on the bobcat or the dozer blade. Will try cracking the fittings on the blade
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
(1) VISSANI REFRIGERATOR (A51248)
(1) VISSANI...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
