Oil & Fuel Hyd oil change pan
   / Hyd oil change pan #1
kbota
Bronze Member
Louisiana
JD 850-sold to buy Kbota Grand L3010
Was in Lowes today, and back in the masonry area, I found a black plastic pan measuring 2 feet by 3 feet by 8 inches deep. If my calculations are correct, this pan will hold almost 30 gallons, and is only 8" deep. For my 4x4
L3010 GST which holds 10.8 gallons of transmission oil, and half that in the front axle, and about a gallon in the FEL, this pan solves a catch and contain problem, that is much easier to use than cut down 5 gallon buckets.
The price is $13, but it should last a loooong time. Looks like it should work nice for transmission, axles, and engines. Smooth bottom which will wipe clean easily.
Just a thought that might help someone. I bought one tonight.
Love my bota
   / Hyd oil change pan #2
Better yet, get a huge drain pan. It can be completly sealed and either carried or rolled on the wheels it has on the bottom when it's full. That's a nice feature since over 10 gallons of oil can weigh a good bit.
I own a couple of these 58 quart drain pans and would be lost without them. I highly recomend them.
Blitz 42008 58 Quart drain pan
That's a real nice oil drain pan, and very handy. Just a tad expensive though.
Thanks for the info.
   / Hyd oil change pan #4
Up until a few years ago I had a mobile fleet service/repair business. The drain pans may have been expensive but they were well worth it. Actually they are rather cheap for the size. Some of the over 50 quart drain pans get into the hundreds if not low $1K range, but they do have a preasure system to empty them using compressed air.
I'm sure they are real nice, and if I was changing lots of oil every day, I would consider one. I just changed the transmission oil in my L3010, and used the el' cheapo $13 pan. It worked great.
Thanks all
   / Hyd oil change pan #6
Nothing wrong with cheap. :) I only purchased them because I really needed them for the business I had at the time.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
