3-Point Hitch Hyd. Issuses on my new toy 1020
   / Hyd. Issuses on my new toy 1020 #1
Towman
1950 ford 8n
Finally got to play with my new toy today 92 1020 gear drive trans with 1014 loader I used the loader for abit this morning worked like a charm decided I was gonna detach the loader this afternoon for easier access to the motor for oil change etc.. Got the loader off no problems at all unhooked the quick couplings and away I go I decided to use the box blade to straighten up some gravel in front of my shop before I put the tractor inside I've had the box blade on the tractor every since I got it it has held it up in the highest point of the hitch for two weeks without bleeding off so as I was leveling the gravel I went to raise the box and it would not raise I shut it off ASAP tried to see any issues but found none except the hitch will not raise at all ????? Any ideas ? Just to verify where do you check the hyd. Level ? Thanks in advance for you help
   / Hyd. Issuses on my new toy 1020 #2
Are the hoses connected properly? I had an issue where the hoses were incorrectly marked which resulted in the hitch not being able to raise?
The hitch worked great and then after setting the loader off it lowered down as it should but won't raise back up its got quick couplings on the feed and return lines under the tractor for the loader I just and there set up to where you can't hook them up wrong 1 male and 1 female on each side of the coupling I'm curious though do the hoses under the tractor need to be coupled together when loader is not on the tractor? I also have a thought that maybe the Hyd. Fluid my be way low I pulled the filler cap and looked inside and couldn't see any fluid at all the book calls for either permatran 3 or 80w gl3-gl4 oil I'm gonna try to drain what's in there if any . Trying to figure out what oil to refill with ...
Got it figured out today I hooked the loader back up and bingo everything went back to normal I beleave the hose ends on the tractor didn't mate up as they should which cause hyd. To stop working
1997 INTL F-4900 (A50323)
1997 INTL F-4900...
2005 JohnDeere 644K (A50322)
2005 JohnDeere...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
Concrete Trowel (A47384)
Concrete Trowel...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
1261 (A50490)
1261 (A50490)
