Hyd. hose question
   / Hyd. hose question #1
Henton
My little ford just sprung a leak on one of its hyd. hoses. Its one of the hoses that goes to the bucket. My question is when changing this hose do I need to "bleed" the system or anything special? Or can I change it and go on without any air in the line to cause it to act-up?
The tractor is a 1984 Ford 1710.
Thanks, Henton
Thanks Will.
I just got off the phone with my brother in law and he said the same thing. Just change hose and work it back and fourth a few times and all will be good.
   / Hyd. hose question #4
And to add,,,,
Replace the hose, don't put a new fitting on old hose.
Might be a good time to inspect the others. Replacing two hoses that are 'side by side' is almost as easy as doing just the one.
Check your fluid level.
Thanks man, Ill do that.
2018 HINO 195 16FT BOX TRUCK (A52576)
2018 HINO 195 16FT...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2017 HINO BOX TRUCK (A52576)
2017 HINO BOX...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
