Hyd hook up
   / Hyd hook up #1
sokoj
I have a Kioti LK 3054xs 4wd TLB. ( Factory loader and back hoe installed) I have a Myer 8 ft snow plow blade attached to the bucket. It has both right and left angle cylinders still attached .I have the angle cylinder hoses attached together so I can manually move the blade from center to right or left and pin it in place . I want to tap into the hyd system and be able to move right/left hydraulically .I have a 4 port spool valve off a wood splitter. Can I just Tee into the pressure hose going to the control valve for the loader and tee into the return side of the control for the loader to get pressure to work the plow blade ???? If not , any suggestions ! Thanks
   / Hyd hook up #2
Welcome to TBN:D
Short answer is NO, you cannot "Tee" into any high-pressure hydraulic lines. All valve must be placed in series with each other.
The proper way is to plumb from the PB (power beyond) port of your loader valve to the IN of the new valve, Then from the PB port on you new valve to where the original PB line was connected at the tranny. The OUT of the new valve can be "Tee'd" to the OUT line of the loader valve since it only carries waste oil from the valve.
Lots more info if you search the term "remote" here in the hydraulics forum. You setup is the same as the Kubota's use.
   / Hyd hook up #4
Since you have a BH installed, it is probably using the PB port.
So what? He can still add another valve inline just as I described.
   / Hyd hook up #5
His [ new ] valve is a used log splitter valve and has no PB port, and he can still connect in series.
I would check on the pressure rating on your snow plow cyl, and set the relief on the log splitter accordingly.
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Sony TV/ Polycom Unit and Stand (A50325)
Sony TV/ Polycom...
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2018 Jeep Grand Cherokee Multipurpose Vehicle (MPV) (A51694)
2018 Jeep Grand...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
