hyd grapple add on questions
   / hyd grapple add on questions #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
I have a B3030 tlb, i am interested in adding a grapple to the front bucket and have a few questions. since i have a BH what will i need to add to get power to the grapple on the front bucket? any ideas, links, experience, and dont do this would really help. I found the grapple i want at greens-machine.com. looks like just what i need.
i know this is a subject that is beat to death on here but i could use the help, thanks fellas
   / hyd grapple add on questions #2
You need something like a diverter/selector valve, solenoid operated. The input for the diverter valve is the bucket hyd curl circuit. The diverter switches the fluid flow either to the bucket curl or the grapple, depending on switch position. Here is one of the most common diverter valves, with schematics.
https://www.surpluscenter.com/item.asp?item=9-5117-A&catname=hydraulic
Select Instructions on the diverter page.
J J, thanks man, i was hoping that with the BH i would not have to do much in the way of plumbing but the solution you gave me looks like a very simple way to get it done. If i understand it correctly you would interupt the hyd. ckt for bucket curl, would you still be able to curl the bucket and operate the grapple at the same time?
   / hyd grapple add on questions #4
It is either /or .
A simple switch would switch the hyd to grapple, and release the switch would put you back in bucket curl .
This sounds like the quickest and cheepest way to get it done. It would be real neat if i could some how find a switch that i could mount by my left foot like an old high beam switch on a car. i may still someday mount a 3rd function setup off the hydro for the backhoe also. I have a 9.1 gpm total output from my system is the valve you gave me the link to going to work since it is 6 gpm or should i go bigger?
your a big help man, thanks
   / hyd grapple add on questions #7
J.J., I don't mean to hyjack this thread, but the valve you reccomend (in #6 above), shows a "related item" - a "Hirschmann Connector". The description for this item states "two required per valve". Can you please explain what this "Hirschmann Connector" is and why it is needed?
Thanks!
John
Exmark LazerZ Zero Turn Mower (A53117)
Exmark LazerZ Zero...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
