Hyd cylinder problem.
/ Hyd cylinder problem. #1
FELMOW2320
Rocky Face,Ga.
Kubota B2650
I have a grapple bucket(single lid) on my B2650 and all was fine until I picked up some crossties the other day.The grapple would touch when you closed the lid before.Now there is a 1 3/4 gap.I took the quick coupler ends off hoping there might be some trapped air in the lines.Nothing changed.I pulled the pin on the cylinder just to make sure the lid would close all the way.It did so the problem is in the cylinder.Any suggestions on what would cause it not to close all the way.
Talked to the manufacturer of the grappel this morning.They said to loosen the end on the shaft and turn it a couple of rounds.They said they had run into this before but couldn't explain why it happened.Adjusted it and works fine now.
2004 Brenner DOT 407 Insulated T/A Chemical Tanker Trailer (A64194)
2004 Brenner DOT...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
2022 EZ-GO ELITE...
2014 CATERPILLAR 924K WHEEL LOADER (A65053)
2014 CATERPILLAR...
