Hy tran Ultra = Ambra Multi G 134??
   / Hy tran Ultra = Ambra Multi G 134?? #1
jduke
Bronze Member
I was trying to order Case Hytran for my Case IH tractor. The new holland dealer says that the tractor (DX55) is the same as a TC55DA and the fluid that should go in it now it New Holland fluid. Are these two compatible or not? I am going to change my steering fluid filter and will lose most of the fluid, but there will still be Hytran in it. Can the two fluids be mixed? The parts on the two tractors are identical...same part numbers and all, so I know the fluid will work by itself, but can I mix it?
   / Hy tran Ultra = Ambra Multi G 134?? #2
We've put hy-tran in fords,MF's,JD's for decades and even mixed with the likes of mal-mart TDH with no problems ?
   / Hy tran Ultra = Ambra Multi G 134?? #3
I'm sure they are compatible but the only way to make sure is to compare the spec for HyTran Ultra and Ambra 134G.
   / Hy tran Ultra = Ambra Multi G 134?? #4
My local NH dealer service department told me that they were not compatible and that they seperate when mixed.
   / Hy tran Ultra = Ambra Multi G 134?? #5
I found this while searching Google for the answer...
"New Holland oil AMBRA Multi-G 134 is comparable to Case IH oil NEXPLORE. Both are CNH specification number MAT3525.
New Holland Oil AMBRA MasterTran is comparable to Case IH oil HY-TRAN ULTRA. Both are CNH specification number MAT3505."
So they seem to be different specs, if this info is reliable.
Case Maxxum 140 (A50120)
Case Maxxum 140...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
2019 Isuzu NRR Roll Off Truck, VIN # JALE5W169K7901549 (A51572)
2019 Isuzu NRR...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
