Hustler ZTR----Broken belts
   / Hustler ZTR----Broken belts #1
Don in LA
South Louisiana
1967 Ford 3000, 42 HP Diesel, 2WD
I have a 2006 Hustler Fastrak, 42" ZTR that throws and breaks belts. In the past 3 years I have replaced all of the deck pulleys. I still throw belts. Yesterday I replaced the deck belt 3 times without being able to cut any grass. As soon as I engage the deck, the belts comes off the pulleys.
Any suggestions on what the problem might be?
Thanks,
Don
   / Hustler ZTR----Broken belts #2
I think it must be a pulley alignment problem but I have no idea what you would need to do to fix it. Look at the belt alignment from the mower engine to the deck and see how much slant it has between the engine and the first pulley, then look at all the spindles and idler pulleys to see how well they align. All the deck pulleys should be pretty much level all the way across. You may also have some missing belt guides (? Little brackets that fit up close to some pulleys to keep the belts on)
   / Hustler ZTR----Broken belts #3
You're using proper drive belts, not automotive style v-belts.
   / Hustler ZTR----Broken belts #4
Is the idler pulley tensioned correctly?
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
