Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference??
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #1
Dave2425
NoDak
JD 3720
My 44" Cub Cadet ZForce that the previous owner of our place is on it's last leg and I'm looking to upgrade. I mow +/- 4 acres with about 100 trees that I drive around.
There aren't many options where I live - Cub Cadet, JD, Exmark and Hustler are my choices. There's a Bad Boy dealer about 40 miles away but I'd rather buy locally.
I've read through dozens of posts on this and other sites and think a 54" Hustler FasTrak is my best option. The dealer doesn't have a FasTrak demo but he's bringing out a Super Z for me to try tomorrow (I know the Super Z is a completely different beast but it should give me an idea of how they drive).
Is it worth spending $1000 more for the Super Duty ($5499 vs $6499)?
The differences that I can see are:
- Commercial series engine
- Bigger air filter
- Foldable ROPS (I'm going to remove due to all of the trees I mow around)
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #2
I thought so a couple of years ago when I bought mine. I mow some pretty rough stuff & have been satisfied with mine. If your ground isn't real smooth, I recommend the flex forks.
Thanks for the reply. The ground and ditches can get pretty bumpy so I'll definitely look into the flex forks.
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #4
I had the same decision to make a little over a year ago and went with the SD.
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #5
- Bigger air filter
For just about every manufacturer it's approx. $1k to step up a "series". The Fastrak is at best a medium/high-end Residential machine and the Super Duty has more Commercial features(just below the "official" Commercial Super Z). The Super Duty is a high-end Residential/entry-level Commercial machine and yes....well worth the extra money for mowing 4 'rough" acres regularly(if you want it to last).
Thanks to everyone for the replies.
I bought a Super Duty with flex forks and it was delivered yesterday.
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #7
Let us know what you think of it after you have mowed with it a couple of times. If this is your first zero turn, it will take a bit to get used to it.
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #9
Also, run the tires at 8 psi. Rides much better. Likely, the dealer put in more. Mine did.
   / Hustler FasTrak vs FasTrak Super Duty - Worth $1K difference?? #10
Locoweed,
The mechanic at my dealer told me to run 2-5 psi "more" than the manual stated for a better ride and I asked him "don't you mean LESS", which is what I've always thought improved the ride(less bumpy if less full of air). He said no....MORE psi gives a smoother ride. I apologize for hijacking this thread's original subject but wanted to throw that out there for me to get some additional advice on the subject(since you brought it up:0)
2012 CAT 277C2 TRACKED SKID STEER (A45046)
2012 CAT 277C2...
Snapper Push Lawn Mower (A42745)
Snapper Push Lawn...
2018 KENWORTH T680 (A45046)
2018 KENWORTH T680...
2006 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2006 ADVANCE...
2011 WESTERN STAR 4900 (A45046)
2011 WESTERN STAR...
John Deere Gator HPX615E 4x4 Utility Cart (A44572)
John Deere Gator...
