Husqvarna YTH 1542 XP
/ Husqvarna YTH 1542 XP #1
jeffspar
ca
I was changing a flat tire on my Husgverna YTH 1542 XP . The tractor was on a slope. When I set it down thought the parking brake was on. Tractor proceed to move down the slope backwards. Jumped on and hit the brake it kept going. Now the transmission does not work. No movement forward or backwards. The belt is attached and turns the input shaft to the transmission.
Called the local shop and they didn't have any ideas. Any thoughts?
/ Husqvarna YTH 1542 XP #2
Sounds like the neutral lever has been activated. Look at rear of machine and you will find a rod / lever with a little bend as a grip. Make sure it is all the way in
/ Husqvarna YTH 1542 XP #3
I am with Allsorts on this.
On hydrostatic transmissions there is always a means to disconnect the drive from the wheels so you can push the tractor is the engine does not start.
On zero turn mowers which have two transmissions there is a disconnect means on each side of the tractor.
Dave M7040
JOHN DEERE 8' HYD BLADE, 3PT (A64278)
JOHN DEERE 8' HYD...
INGERSOLL-RAND VR-5300 TELESCOPIC FORKLIFT (A65053)
INGERSOLL-RAND...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
