Husqvarna sprocket change question
   / Husqvarna sprocket change question #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
How ofton should the chain drive sprocket be changed on a Husqvarna 450e? Is there a scheduled change required? Is there an indication it needs changing?
   / Husqvarna sprocket change question #2
According to the manufactures the sprocket should be replaced with every second chain, in reality they will last longer.
Thank You. I use more than one size bar so have not actually replaced a chain yet, but still using same sprocket since saw was new, about 4 years ago. I have two chains for each size bar (one 16" and one 20") and rotate through depending on cutting project.
2012 Nissan Quest Van (A48082)
2012 Nissan Quest...
2009 Mini Cooper Clubman Sedan (A50860)
2009 Mini Cooper...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2011 Ford Fusion SE Sedan (A48082)
2011 Ford Fusion...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A48082)
2022 K-Z Sportsmen...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
